Druk
Gone but not forgotten - RIP
- May 28, 2004
- Location
- Not far from Edinburgh.
- 2011 S212 E350CDi. 1981 R107 300TurboDiesel.
Can anyone describe some of the warning signs of a failing wiring loom?
Check the loom, look around the injectors, coils and sensors for signs of failed insulation. Mine had the low tension wires replaced at some point, so they looked good, but they had been spliced into a failing loom. If it's starting to go my recommendation is sort it before it does play up. It can damage ECU's if it shorts.
If the engine loom is poor the chances are the throttle body and lower harness is as well, slice open a couple of inch's of insulation and take a look.
I've just had mine rebuilt by Si-leck and very happy too. It took around 3 weeks, came back nicely labelled, fitted perfectly and quick to install. The car started and settled into a good smooth idle, everything working fine.
A pic below of the lower harness. The insulation crumbles as you disturb it, it's pretty obvious when it's gone.
Have a close look at where some of the wiring emerges from engine connector plugs at and around the front of the engine. The camshaft plug for instance. Usually there's a 1/2" or so of cable exposed before it disappears into a sheath. If there's any sign of crumbling insulation there then a closer more intimate look at the coil wiring is recommended. However this is usually intrusive and if damage is found then the engine really shouldn't be started until full remedy is done. One turn of the key with ignition wiring which has been disturbed can be enough to fry the engine ECU.
