BlueQuinn
My 300TE-24 wants more money :-(
There are a couple of symptoms:
A smell of petrol inside the car. I lifted the bonnet tonight when I got home and there was a fuel leak under the air cleaner on something that joins the inlet manifold forward of it.
When it's being driven in traffic, if it's stuck there for very long and everything gets warm then after a while when you pull away from a standstill it will bog down and almost stall and for a while it won't go anywhere. Then if you persuade it go go with a bit more gas then it will zoom away too fast, like massive turbo lag). When this happens the only way to get it to drive reasonably safely is to use the autobox like a manual and start off in 1-2 every time. Even then it's dicey.
I've read about EFAs producing this symptom. Is this it?
