W140 windscreen washer nozzle
frog1520
Does anyone know how to get the washer nozzle off? I think the washer hose has come off the one on the end, but am having trouble getting the nozzle unit out of the bonnet.
Alldatadiy.com talks about a special tool (140 589 18 63 00) to undo the clips - anyone know if you can just do it with a screwdriver or what the tool looks like so I can try and make one!
Thanks!
I took one of a W124 with 2 small screw drivers. Not sure its the same on a W140 though.
There's a flip up latch/cover that you open on the underside of the bonnet under each nozzle(may need a small flatblade) and the things pop out. The pipes came loose on the drivers side and middle ones on mine.
Thanks for that!
The passenger hose came off on mine, so between us, we have a complete set! :bannana:
Cheers!
