- Jan 21, 2005
- Location
- Mittel England
- Smart ForFour AMG Black Series Night Edition Premium Plus 125 Powered by Brabus
The ML passed it's MOT at the weekend but the tester commented that the parking brake would benefit from being adjusted - slightly weaker on offside.
Just Googled and found what would appear to be a useful MB-dealer document, but curious if anyone here has done it? Available here:
http://ww2.justanswer.com/uploads/mbpaul/2009-09-13_190332_Adjust_parking_brake.pdf
So if I understand this right the parking brake can be adjusted WITHOUT removing the wheel - just need to remove a single bolt on each rear wheel - and then adjust using a screwdriver through the now empty bolt hole.
Is that right? Almost seems too easy!!
If the above is correct, then I can't see why the document flags a risk of damage for alloy wheels, as it seems less likely to damage whilst adjusting that removing. What am I missing?
How do I found out if I have push-notch or pull-notch pedal assembly?
