W163 Power to Aerial Amp
topdown
E500
I fitted an after market Double Din with an ISO connector that has a matching connetion to the Pin on the Audio 10 for Aerial. The Double din unit has this output for an automatic aerial. However FM reception is poor and AM no signal. I checked that the Coax is OK because when I disconnect there is no FM reception at all. Refitted the Audio 10 and FM / AM is great
Do I need to supply an ignition switched +12 v to the Aerial Pin on the car side of the ISO to power the aerial amp?
Tks
