My little A class handles well at normal conditions on good well-surfaced roads.
Unfortunately, the car is in Bristol and not in Germany. As you have guessed there are not so many good roads here (thank you Bristol council). The surface is very bumpy, almost as if the tarmac was damaged by tree roots and moles. A class doesn't seem to like that and the steering wheel starts to wobble out of the bumps. It almost feels like the car is doing it itself. Slippery white road markings seem to have some effect too. When that happens I have to hold on to the steering wheel and try to keep it steady.
I did a hard breaking test from 50-60 mph (only did once so far just to test it when it was clear behind me), and the steering wheel starting twisting and pulling the car to left and then to right. I had to balance it myself with quite a lot of force.
Yesterday, I disabled ASR when moving, and I *think* stability clearly improved back to "normal". ASR comes back on after a couple minutes so the workaround is not very practical.
Any ideas if such behaviour can be treated - or is it "normal" for a Merc?
