Grahamcol
This is going to sound silly. My Haynes manual tells me simply to undo the oil filter cap (I have the large fluted tool) and remove the old element, put in the new element and replace the cap using a new cap "o" ring. Fine then. However, I see from this forum that other models oild filter change instructions refer to two additional "o" rings fitted inside the oil filter housing (on a spindle). My Haynes manual doesn't show or refer to these and the new Mann brand oil filter I purchased from Euro Car Parts only incorporates the oil filter cap "o" ring. Am I correct in thinking that on my 1997 model C200 there are no internally fitted o rings ? Sorry for a silly question but although I've changed oil etc on many cars in the past, this will be the first time I've done it on this car. Thanks.
