Hi guys. It's been quite cold recently and I have noticed that the heater isn't doing it's job. ![Frown :( :(](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f641.png)
Symptoms:
1. When I set the temp to max, the temp can best be described as nothing more than lukewarm
2. When I set the air speed dial from 1, say to 5, there is an increase in air output, but it is very very slight
Any ideas where I should start? I initially thought it might have been in part due to a clogged cabin filter situated below glovebox in passenger footwell, but having changed it, the problem is still there..
I have researched / looked into past threads on this but am not sure what to begin with:
1. Duo valve issue?
2. Replacement blower motor motor brushes?
3. Heater control panel needs replacing?
EDIT: found a useful link of heater motor removal, if that is what I will need to do![Eek! :eek: :eek:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f631.png)
Symptoms:
1. Duo valve issue?
