StavFC
Few things...
Has anyone fitted aftermarket exhaust parts to their W202 C230 Kompressor and got any proven gains?
Ive seen claims of aftermarket manifolds giving 20bhp and exhausts similar mounts, but after looking under the car, I find it hard to believe
The manifold is a tubular steel 4-2-1 item that is fantastic for a standard car, and the rest of the system is a decent diameter and even doubles as it goes through the restrictive cats; only potential big restriction is if the silencers are, but without removing them to look, I cant tell.
The electronic supercharger bypass throttle thing. How/when does it operate? Open on light/off throttle, and closed at all other times I presume?
Has anyone tried blocking the pipe so the air is always fed through the s/c? Reason being I cant see it being all that air tight, making for a permanent, and performance losing, boost leak.
As a pulley change for more boost looks stupidly expensive (unless I missed a better priced version?) thats out the window, but have seen remaps for sale with no mention of more boost. Has anyone had their 230K remapped without a pulley and it made a worthwhile difference?
A decent intercooler sprang to mind straight away, but looking at the way the pipework is just before the IC, there no chance without big changes, due to the pipe being a v.odd squashed setup to clear the radiator etc
Unless ive missed something?
Anyone tried pre-compressor water injection? Ive done it loads of times on other turbo and supercharged cars, and tbh it should help a lot, but would be interested if anyone had done it.
Traction control- Does it turn totally off? I heard it doesnt, but sure seems to by pressing the switch on the dash? Smokes the tyre (just one, damn open diff!) through 1st and 3nd with it 'off' so? Mines a 'Sport' if thats what makes the difference.
LSD- Is there one available? Open diff sucks and I wont want to have to settle for a welder if I dont have to.
FINALLY- Feels like a dual mass flywheel to me, correct? Is a single mass flywheel and clutch available for them? Cant imagine a dual mass lasting me 5mins...
THANKS!
THANKS!
