For the past 2 months my rear passenger electric window has not worked, although I can still hear the motor working/grinding the window would not move.
So yesterday I decided to investigate by taking the door apart.
It appears the mental cord that the motor pulls up & down has snapped (rusted through as it appears?!?)
Im sure I can simply untangle it and refit a new one as the motor seems fine.
Question is, how on earth can you remove the motor? As far as I can tell its attached via the vertical beam by 2x torx screws (see picture).
Problem is, how the hell can you unscrew the torx screw? its facing the inner door panel with only 1" clearance?
