skymastor
- Dec 22, 2006
- Location
- South Yorkshire & NRW Germany
- C240 Avantgarde with AMG Styling
Hi Guy's
For over a month now, I have had an intermittent problem in the mornings which has now developed into an everyday occurrence, whereby my car is completely dead!! No operation with the remote and nothing when I place key in the ignition!! I have to open the car with the skeleton key (alarm going off!), pop the bonnet and take off the negative battery lead and then replace it to enable the car to accept and recognise the key in the ignition and also open by the key's remote.
It is similar to this problem in this post from 2007:
http://www.mbclub.co.uk/forums/electronics/44052-w203-c320-2001-no-electrical-power.html
The battery on my vehicle is fine and when I reconnect the battery, as with the post above, everything springs to life!! Its as if it has been re-set by disconnecting and re-connecting it again!! When I run my DAS system after this event, I have the following errors stored:
EZS - Electronic Ignition Switch
Code: B1000 - Control Unit N73 (EIS[EZS] control unit is defective.
Status: Stored
ICM - Instrument Cluster with Maintenance Interval Display
Code: B1124 - The main reading is incorrect (too low).
Status: Stored
Code: B1109 - Fault in CAN bus communication with Control Unit N73 (EIS[EZS] control unit. Important note: the fault code can be ignored if it is possible to establish diagnosis with Control Unit N73 (EIS[EZS] control unit.
Status: Event Stored.
Well, I can clear the faults and everything is fine all day long, until the next morning when it is all repeated again!
When I run DAS diagnosis on N73 (EIS[EZS] control unit and specifically the the Transmitter Key and Drive Authorisation, everything is as it should be, showing no faults!! Even after the event and the above faults are still in memory!!
I clear all faults and things are good all day, but its the same procedure again the following morning!!
So, it appears that DAS communicates with the N73 (EIS[EZS] control unit perfectly without errors, but in the mornings the car is dead showing it faulty!
Does anyone know if this is a common problem with this unit, whereby is can be faulty intermittently? Or maybe a loose connection somewhere that DAS cannot highlight?
Any suggestions appreciated.
Ta...
All,
This is a strange one, that perhaps somebody has an idea on.
We have a 2001 W203 C320, and this morning my dad went to start it, and nothing happened absolutely dead. So he opened the door with the skeleton key, no power to instrument cluster, courtesy lights absolutely dead.
The battery was new 3 months ago, (For additional info this car has in the past had a battery drain problem from COMAND which has been resolved, personally I don't think this is relevant)
Anyway, he put the car on the trickle charger, and within 2 seconds everything sprang to life, alarm went off, lights on, and started first time with the key, which suggests to me that there was no issue with the battery.
Any ideas welcome?
Status: Stored
Status: Stored
Ta...
