W203 coupe star mods
jim_bob567
Derbyshire
C220 cdi coupe
I am in derbyshire, looking for someone with a star machine reasonably local to me for some modification programming, any recommendations? i would also like this to be done for quite cheap if poss, i'm looking for mods such as mirror fold on locking, cornering fog lights, dipping passenger mirror on reverse and anything else that can be done! it would be helpful if anyone can provide a list of all the mods that star can enable. Any help greatly appriciated, James.
Hi James. I can 't help with the Star programming but suggest you put you model year and spec I.e memory seats, comand etc. This will help someone help you more easily.
Alfie enabled on my w203 facelift 4-door (MY 2006) the following:
1. Aufo folding external mirrors (possible only if you have the 'press-briefly-and-let-go' type of switch)
2. Delete UK mode - allows for outside temp to be permanently displayed on cluster screen
3. Show fuel tank capacity in gallons on cluster screen
4. Enable tyre pressure monitoring - that's the basic version that relies on the ABS sensors input, not the one that actually has tyre pressure senders fitted in the tyres' valves.
It is also possible to have a date display on the cluster screen, but this was not enabled in my case.
The dipping-when-reversing external mirrors function is to my knowledge only available with the memory seats option.
The cornering fog lights function I believe is only available with the Xenon lights (HID) option.
As said, this was done by Alfie - Comand Online Ltd
Highly recommended. Both the mods themselves and Comand Online.
