W203 Creaking drivers seat.
terrymcg
Perth, WA.
W164 ML 320CDI
My drivers seat squeaks and creaks when going over bumps.
I have read on a forum from over the pond, its is caused by some springs from under the base drying out. And some PTFE spray etc will stop it.
Can anyone clarify this? Is it a seat out jobby, as I cant see any springs from the underneath?
Cheers!
w203 squeaky seat
My C Class has leather nd did the same, i worked out it was the plastic trim on the right side. by the seat adjusters, i used a window shammy and cured the problem.. and always have a shammy in the car
use the spray and see how you go, it's cheap and could well fix it
The rear of the seat base has springs that cause creaking. Plastic vs plastic. Remove the base and grease the contact points. Very common issue on 203's
