JonTallis
Update....
Cleaned all terminals.
Checked the fan is free to spin when installed - all OK
Checked voltage into the resistor - full 12v
Checked for voltage on the 3rd wire on the input plug which I presume is the speed signal. This varies from around 4v on minimum fan to 12v on max fan. No idea if this is right but it seems pretty logical.
Voltage out to fan is all over the place but not more than 2.5v so fan not running.
Have tested with both the old resistor and new (Chinese eBay) one.......didn't want to spend £150 on a pattern resistor or £300 on a Merc one until I knew that was the fault.
So........either both resistors are faulty or the input voltage from the fan control is haywire.....my money's on the former but if anyone can confirm what the input signal / voltage to the resistor is supposed to be that that would confirm......
