W208 55amg oil filter housing removal
astamir
london
w208 silver clk55
Hi guys wish you all the best
As it says in the topic of the thread I'm trying to remove the oil filter housing to change the seal under it, and needed help to identify the size of the bolt that fits inside the housing
Going through the mb forums I found the thread where the same job was done on m112 engine and the bolt size on the m112 was 46mm
Would it be the same size on my m113 engine?
Thanks in advance
The M112 engine is very similar bar 2 cylinders less. I'm not 100% sure, but it probably is the same size.
