W208 clk200 rough idle when cold
666bxg
hi
i recently had my ECU replaced with a used one after it blew. everything was going on fine until about 1 month after the ECU was fitted
from cold starts i'm getting a rough idle, and occassionally would stall once D is selected. if left for a few mins everything will be fine. alternatively if i switched the engine off and on again, the problem is solved
could anyone help point me in the right direction? MAF? O2 sensor?
thanks in advance
