Hi All
Mrs M came home from work today and as we were chatting over tea, she mentioned that her brakes were making a grinding noise. Now I immediately thought worn pads, as you do but was bothered why the wear sensor did not indicate anything.
So took it to the end of the road - really loud grinding from drivers side. Now we have not had this long, and I know when I checked the car over the pads had a good amount on them - so took off the drivers front wheel and looked to see if I could spot anything wrong.
It appears there is loads of life left in the outboard pad, absolutely nothing left in the inboard pad - I never took the caliper off as it was getting late and dark - but have tried to find some guidance on here for a similar fault.
Do you think the caliper is shot? The pads are definitely, as is the inboard side of the disc - very scored. She is certain she only noticed the grinding on the way home - it looks to me like the pad is missing on the inboard side. Passenger side is ok.
Anything I can do aprt from change the pads and discs? Is it essential to change as a pair (L and R) or ok to change just the drivers side?
Cheers for help and thoughts
Matt
Matt
