W208 Convertible - Subwoofer connections
tpwuk
Fylde Coast
E350 BlueTEC W212
Guys,
The previous owner of my CLK fitted an Alpine system, which sounds fab! However, I'm pretty sure that they have not hooked up the subwoofer. The Apline has dedicated RCA output for connection to a sub. What's the best way of connecting this to the Mercedes sub? Any ideas?
Cheers,
Glenn
I assume you mean the Subwoofer RCA output from the headunit. If so it is not for connecting direct to a subwoofer.
Sure I know what you mean. What drives the Sub in the CLK? Does it have an amp somewhere?
Sounds like you had BOSE but an aftermarket audio system has been fitted? If that is the case the BOSE is probably disconnected.
Best list exactly what audio system you have and what the Alpine system consists off.
The Apline is a CDE-103BT. I wasn't aware my CLK had the Bose system due to the lack of Bose badges on the speakers and sub. Don't "none-Bose" CLK's have a subwoofer?
I still have the original Mercedes headunit (Audio 30) and CD changer in my garage.
Yes - the 'standard' CLKs have sub-woofers also. I imagine that it would run from your head unit RCA output (It is self-powered), but it's a rubbish unit. If you decide to replace it, use a 'standard' 8" sub-woofer and a decent small amp. No need to go to all the trouble of chopping and adapting to fit a bigger unit in (as I did); I found out it was too powerful and leads to all sorts of pain trying to damp out resonance all over the place!
The bass response in the car is pretty good as it is, so maybe I won't be adding much by continuing down this road.....especially if the standard sub is pants anyway??
But if I were to pursue it, does the standard sub have RCA inputs and were would I access them?
The standard sub doesn't have RCA connectors. It just has a mulitpin connector into the car loom. I'd guess you could trace 2 of the wires through to the original head unit connector somewhere in the dashboard. There's a chance that it might need a speaker level input though (even though it has its own mini amp - or is it a crossover?) so you'd have to check the output on the OE head unit just to be sure.
I can't see you adding to your current sound quality though - whoever put your Alpine in must have thought they could live without the OE sub (not a hard decision!).
Are your door speakers original? I replaced the fronts on mine and disused the second pair in the rear of the doors - I thought they just muddied up the sound & I wouldn't need them with a decent sub. Turns out I might have been better keeping them and not bothering with a sub - the rear bulkhead that it sits in really limits how much you can actually do with a sub.
I can get reasonable sound (I spent eight hundred quid on an amp and speakers!) but I seem to have to juggle the bass/treble/fade settings for each different track. And, I'm limited by all manner of different bits of trim etc. starting to resonate if I crank the sub up beyond 'noticeable'.
The mercedes sub is not very good, dont waste your time, as you already have the RCA`s on the Alpine head unit just hook up another amp and sub, job done.
Or an active sub then no amp needed.
my w208 had a bose audio installed with the sub, yes it did have an amp which was located behind the metal plate in the boot where the roof motor is also.
I had mine stripped out and a complete alpine set up install as the standard bose set up wasn't that good at all :( - but now the alpine really does the trick!
