W208: Creaking - ARRRGGHHH!!!!!
This morning before coming to work, I gave all the bolts a little bit more of a turn and 75% of the journey was pretty much creak free! So the bolts must be coming loose. I just nipped to halfords to buy some thread lock and the creaking is worse than ever! Hopefully the thread lock will do the trick. Fingers crossed!
Thread lock should work fine mate, easy to use and dries quick. Probably best to do it in the evening when you know you will not need the car and allow it dry properly over night.
This will prevent the bolts from loosening and prevent your dreaded creaking :-)
Can the bolts be undone easy enough afterwards?
Yup, they are a little harder though, but still manageable
