OK, I've read all the threads I can find, here and elsewhere, regarding poor FM reception.
I have an early 05 facelift W209 (UK RHD), the FM reception isn't as good as I remember it to have been a month ago, I'm getting dropouts and the stations I listen to can't be received in areas where they were OK before.
I've looked at the aerial amp under the headlining at the top of the rear screen; it appears to be properly fixed and all the plugs are connected (as far as I can tell without stripping out the headlining completely).
I've looked at the rear fusebox (left hand of the boot) and checked fuse 8, OK.
I've taken the Audio20 HU out and checked the connections and cables, all appear OK. If I remove the black FAKRA connector the FM signal disappears completely, if I remove the mustard (antenna diversity) plug instead it makes no difference that I can hear.
The central locking is working fine, the range is good, so the R.F. locking pickup in the rear screen appears to be OK.
Does anyone have any ideas what might be causing the low FM signal, I suspect that the diversity antennas might be the problem (does anyone know if there are hidden connectors in the cable for instance), or is it possible that the antenna amp(s?) are not working correctly?
Any suggestions welcome, thanks.
