EDZ649
Over the weekend I successfully carried out a repair to my failing cluster pixel displays for the temp, clock and gear selection. They are now perfect.
During the process something has happened to the very top of the mileage display lcd where the trip meter is. This section is now blank right accross the top of the screen.
I've checked the lcd panel carefully and there are no cracks etc.
I can only assume there is a break in one of the wires in the ribbon cable or a crack so small it's not visible.
Anyway, does anyone have an old cluster lying around, working or not where the centre lcd panel is ok? Or does anyone know where you can buy a replacement lcd panel for this part of the cluster?
Thanks.
Thanks.
