I could really use some advise with my car please...
I purchased an E320 CDI 2007 V6 facelift model just over a year ago with full MBSH & 42500 on the clock. Car needed a service 'E' at the time and was a couple of weeks overdue so I only drove the car very gently for 300 miles or so and booked it in with my local Mercedes dealership.
Part of the work involved was an ATF change and they also replaced a leaking oil o-ring seal on one of the turbo pipes.
A couple of weeks from having had the car serviced I started experiencing very jerky revs when in 2nd, 3rd, or 4th gear. This would only happen when I accelerated quite hard or when using the kickdown function on the accelerator. This would happen very intermittently, with the engine & gearbox fully warmed up or from cold, and in both C & S modes on the gearbox.
I would on occasion also experience a loss of power from the car, and it would go into limp home mode until I pulled over and switched it off and back on again - something which cured the jerkiness 99% until the next day / week / etc.
As it was very intermittent I didn't do anything about it, and it was happening so rarely that I just left it until the next scheduled annual service (a 'C' service this time). I took the car back to the dealership & asked them to investigate the problem.
They reported the following fault codes:
2510-001 - Check component Y77/1 (Boost pressure regulator). Positioner signals fault. (STORED)
2616-002 - Check component B60 (Exhaust back pressure sensor). Control variation - Exhaust backpressure is too high. (STORED)
2644-011 - Check component B2/6 (Left hot film mass air flow sensor). Value is above limit. (Current and stored)
They recommended replacing the MAF & O2 sensors, as well as a clean of the air line. I authorised the work even though this was, to me at least, a massive cost of £754.
Just 2 days after collecting the car the problems re-appeared, I took the car back and they replaced the air filter, boost pressure sensor & reset the adaptations (all FOC) and were convinced this would now solve the problem. Interesting to note here is that they told me they found no more error codes on the car before carrying out this work.
The car had the same problems again a day after I collected it so I took it to an indie who scanned the car and found the same three error codes listed above.
I have now taken the car back to Mercedes who have had it for yet another week and have just received a phone call telling me that my turbo unit needs replacing to cure the loss of power problem (due to error code 2510-001) but they do not know what is causing the car to be jerky...they suspect it might be the exhaust manifolds but would like to replace the turbo unit first.
I have searched these forums (and others) and can see that there have been a few W211 series owners who have had similar problems.
Can anyone help me with these codes because I do not have £1800 to spend on replacing the turbo, nor a further £1200 to replace the manifolds, especially when Mercedes cannot tell me that doing either will definitely fix the problem.
Posts I have found with owners having similar problems are here:
01; 02; 03; 04; 05
01; 02; 03; 04; 05
