- May 7, 2007
- Lexus RX450h F-Sport with Takumi Pack 2020
reported
This will be very likely a turbo issue.
Seen it a few times and is quite common.
Hi there,
I'm having a similar issue with my E320 CDI, a 2005 I6 3222cc variety.
My hiccupping is really only noticeable when the car's cold, or at lowish (sub 35), constant speed. The rev counter fluctuates a bit, I feel a slight hesitation. And when I do a long run I sometimes get a limp mode after stopping for a bit (leak and a coffee for example) and restarting whilst the engine is hot. Then, another stop and switch off/on and it clears. No engine management lights or the like.
A local Merc indie is blaming the torque converter and the turbo (a code on STAR only gave an error on the turbo sensor, they said it was an integral part to the turbo and would necessitate whole turbo replacement), I had them do a transmission oil flush and change, they said the old oil wasn't nasty at all. So maybe, just maybe, the TC is OK and all will be solved with work on/replacement of the turbo. If I can sort it with just the actuator I'll be a very, very happy idiot.
Any thoughts or advice please?
My W211 om642 does this sometimes, feel like you'reHi,
I could really use some advise with my car please...
I purchased an E320 CDI 2007 V6 facelift model just over a year ago with full MBSH & 42500 on the clock. Car needed a service 'E' at the time and was a couple of weeks overdue so I only drove the car very gently for 300 miles or so and booked it in with my local Mercedes dealership.
Part of the work involved was an ATF change and they also replaced a leaking oil o-ring seal on one of the turbo pipes.
A couple of weeks from having had the car serviced I started experiencing very jerky revs when in 2nd, 3rd, or 4th gear. This would only happen when I accelerated quite hard or when using the kickdown function on the accelerator. This would happen very intermittently, with the engine & gearbox fully warmed up or from cold, and in both C & S modes on the gearbox.
I would on occasion also experience a loss of power from the car, and it would go into limp home mode until I pulled over and switched it off and back on again - something which cured the jerkiness 99% until the next day / week / etc.
As it was very intermittent I didn't do anything about it, and it was happening so rarely that I just left it until the next scheduled annual service (a 'C' service this time). I took the car back to the dealership & asked them to investigate the problem.
They reported the following fault codes:
2510-001 - Check component Y77/1 (Boost pressure regulator). Positioner signals fault. (STORED)
2616-002 - Check component B60 (Exhaust back pressure sensor). Control variation - Exhaust backpressure is too high. (STORED)
2644-011 - Check component B2/6 (Left hot film mass air flow sensor). Value is above limit. (Current and stored)
They recommended replacing the MAF & O2 sensors, as well as a clean of the air line. I authorised the work even though this was, to me at least, a massive cost of £754.
Just 2 days after collecting the car the problems re-appeared, I took the car back and they replaced the air filter, boost pressure sensor & reset the adaptations (all FOC) and were convinced this would now solve the problem. Interesting to note here is that they told me they found no more error codes on the car before carrying out this work.
The car had the same problems again a day after I collected it so I took it to an indie who scanned the car and found the same three error codes listed above.
I have now taken the car back to Mercedes who have had it for yet another week and have just received a phone call telling me that my turbo unit needs replacing to cure the loss of power problem (due to error code 2510-001) but they do not know what is causing the car to be jerky...they suspect it might be the exhaust manifolds but would like to replace the turbo unit first.
I have searched these forums (and others) and can see that there have been a few W211 series owners who have had similar problems.
Can anyone help me with these codes because I do not have £1800 to spend on replacing the turbo, nor a further £1200 to replace the manifolds, especially when Mercedes cannot tell me that doing either will definitely fix the problem.
Posts I have found with owners having similar problems are here:
01; 02; 03; 04; 05
Sorry hit the wrong button. My om642 does the same. Shame Mercedes make such a nice car but don't really know whats going on.Hi,
01; 02; 03; 04; 05
It’s an old thread buddy , Lord A was last seen 2018My W211 om642 does this sometimes, feel like you're
Go and see Alex at AMF Mercedes , Tonbridge , Kent . He’s an MB specialistSorry hit the wrong button. My om642 does the same. Shame Mercedes make such a nice car but don't really know whats going on.
Didn't notice. Not hovering to jump on comments, got more to do.Go and see Alex at AMF Mercedes , Tonbridge , Kent . He’s an MB specialist
I thought you had a car problem ?Didn't notice. Not hovering to jump on comments, got more to do.
The fault code does not get stored until the fault happens three times. The fault code can be seen if the engine is left running. Its often shows as low manifold pressure.Hello Billy, thanks for taking the time to reply, i had initially thought that the replacement actuator which I had bought maybe faulty so I had it sent off and a replacement actuator was fitted but the symptoms still persist, how much was the new complete turbo inc the actuator?
The car just doesn't feel responsive as it was
when i purchased it back in September with 110,000 miles i can hear the turbo spinning with no whining noise etc however i suspect the problem lies elsewhere as the electronic actuator doesn't seem to move as it should and the car doesn't feel powerful enough untill revved up to 2500 3000 rpm feels like the turbo isn't working properly up until 2000 rpm, i also had the inlet port shut off motor bypassed but that did not make any difference to the power/ jerkiness
I had a full service carried out by a mercedes specialist who reported no faults or codes on the car, its now done 113,000 doesn't have any other problem
