Dec 7, 2015 #1 4 4life211 Active Member Joined Jul 14, 2015 Messages 301 Car mercedes 211 Hello there.my mercedes w211 has check engine light on and it won't pass 2500 rpm with max speed 130 km/h.it doesn't go faster . Every opinion can help .thank in advance.
Dec 7, 2015 #2 T tec Active Member Joined Mar 31, 2015 Messages 603 Location South Midlands UK Car CLK320 CDi SPORT V6 Double posting is not going to help you. It could be anything. You need a code reader, or get someone to read it for you from the OBD port.
Dec 8, 2015 #3 OP OP 4 4life211 Active Member Joined Jul 14, 2015 Messages 301 Car mercedes 211 tec said: Double posting is not going to help you. It could be anything. You need a code reader, or get someone to read it for you from the OBD port. Click to expand... I suposed that someone might have had the same problem . But thanks anyway
