Hi all,
I replaced my Blackberry 9800 with a 9810 the other day and spent a good while trying to pair it up with the COMAND blue tooth system.
Tried over and over again with no joy. It would sometimes appear to be connected for a few seconds before disconnecting.
The the "Bluetooth" option disappeared from COMAND "server" menu. How odd.
Then asked a mate to try to connect his phone - it would "connect to audio" but nothing else. Mine was doing the same at this point - turning off the audio on the actual handset without actually switching on the audio on COMAND.
Then I noticed that the handset seemed to be switching to bluetooth audio whether I wanted it to or not. Even when the car was parked up with the engine off and key out of the ignition.
And two days later my battery is flat as a pancake.
My crude diagnosis is that the MB Bluetooth system has thrown a wobbly and is constantly on and is draining the battery (is this actually possible?).
Also, strangely, the RH and central audio channels started occasionally disappearing at the same time - sometimes when I had the tuner on sometimes when I had the CD changer on and sometimes when I had the CD player on. This happened at the same time as when the Bluetooth option disappeared from the COMAND menu.
All very odd. I'll get the AA over tomorrow to get the car fired up an I guess they'll be able to test for a current drain if not isolate it.
If I lived anywhere near Comand Online I'd drop in there but I'm in London.
Any idea how I can get a diagnosis? Will STAR show anything?
Has anyone else seen any symptoms like this?
Any suggestions gratefully received.
