w211 e320 cdi weird cold gear change 5 speed
GSI-jim
Essex
w211 E320 cdi
In mornings if i drive really gently on throttle the box feels like it changes in i think 3rd really early & so the revs drop right down. Also feels like the car pulls as it changes up through low gears. It only lasts for about a mile. Any ideas?
Depends if you are in C or S mode
C = Comfort gear box pulls away in 2nd gear and shifts up early.
S= Sport mode so quicker changes and has adaptive learning to your driving style.
That's what I have always understood.
I drive it in 's'. Standard mode.
ive done gearbox fluid & filter change, wiring plug, & fitted a seperate cooler.
i reset adaptions via snap on scanner after i done all that but the engine & gearbox were hot so perhaps i'll do it when its cold.
any other ideas??
its definatly not right
S= Standard is not right.
A MB Star session on the box might reveal something.
Ive got 'S' & 'w'
i read it was standard & wet mode : -/
anyone essex way got the STAR?
Ive got 'S' & 'w'
Ok if you have W & S
S= Standard and the 'box starts in 1st gear and changes up higher in the rev range. One would normally use this setting.
W= Winter and the 'box starts in 2nd gear and will change up sooner than in S.
As similar to my earlier post just the terminology differs.
