Exploding Ball Joints.......
Some ( long ) time ago, I had to replace the front lower ball joint on my Sprinter 312, the ball joint is almost identical to the 211 one, bar the fact that it is fitted upside down and you have to remove it downwards. It is a right pig of a job, space is restricted, and I did not have one of the removal tools. I see you can now buy a ( expensive ) hydraulic tool which removes them in minutes.
The lad at the MOT Garage warned me that he had had them explode in the past and so to be careful.
Anyway, I tackled the job, and some time later after I had my big propane burner on the ball joint and it was glowing red, the ball joint exploded with a big bang, driving the pin an inch into the tarmac and frightening the life out of me. I thought that the propane bottle had gone bang ! , and It was a good job my foot was not in the way at the time. At least I was able to bash the joint out easily after that. However, I was told afterwards that it is easier to remove the arm and do the job off the van. Not only but also, a new ball joint from Mercedes was as cheap as a foreign part off of Ebay !.
Steve.
