Seamster15
I don't have a problem with the mileage as this car should be able to do it easy (with the proper servicing!), I do however have a problem with the short MOT!
never mind...
never mind...
If the auction ended at £4500, I reckon the buyer could use it to part exchange with a dealer for another car and get offered more than that in P/X.
I think there are too many electronic modules to run one of these cheaply.
Are you making him croissants and coffee at this time on a Saturday morning John ?
Don't upset him , or he'll get the hump ....
I don't think that is a reasonable assertion.
It's a very reasonable assertion. The Amercian consumer reports organisation (similar to our Which) rated the electronic reliability of the W220 as poor, their lowest rating. Instrument cluster problems are well known for example.
We'll have to agree to disagree. Neither CR or Which get much points from me for the scientific accuracy/credibility of their reviews, especially not for segments like the s-class where the statistical relevance of their data wouldn't pass the test in a first year graduate course.
Apart from sample size and composition problems, their rankings are based on an opaque ranking system. For example, does a pixel failure on an instrument cluster really qualify as severe as a breakdown that totally immobilises the car? None of these consumer organisations uses an accepted, standardised scheme for assessment and ranking in this respect.
And while for example instrument cluster problems are indeed reported for the s-class, the majority of users still never has experienced one (and I am amongst those).
In contrast to CR reports, for example, Forbes refers to the 220 chassis cars as "built remarkably well".
Have you read the CR reports over the W220 production run ?
Which ones?I read (some?) of their published reports and the Fortune report on the reports.
It's a subscription service like Which. Clearly you've only read the conclusions not the detail.
I think I'm OK at interpreting the presentation of data, I've got a degree in Economics !
At the end of the day something controlled by electronics, like for example a seat, is going to be more problematic than one moved by levers once a car is older.
Access can also be a problem on complex cars. One infamous example being the W140 air con evaporator which is listed as a 20 hour dash out job by Mercedes and on an older car will certainly need doing at some point. On a simpler C-Class it's easy to do.
Bluntly, the V/W220 is a fantastic car, and certainly not unreliable 'per se', but due to it's very complex nature (it has to be from a design point of view), it presents a far greater chance of suffering from some sort of fault than with a less complex car.
It stands to reason that all things being equal, a car with twice as many components must surely be more likely to fail than that of one with half as many?
Not necessarily, it depends on the probability of failure per individual component, which is something that has improved - technology does evolve.Will said:It stands to reason that all things being equal, a car with twice as many components must surely be more likely to fail than that of one with half as many?
This car by design has more that can go wrong, and would be more likely to suffer from a failure - as nice as it would be to own![]()
I think that's what sums up the S-class to me, as reliable (and possibly more so in some ways?) as any other MB, but more likely to have expensive failures than some models due to it's complexity.
Electronic components do age though, and will start to fail with increasing frequency as the car gets older. Cars are not good environments for electronics with vibration and variable temperatures.People tend to focus on examples such as electric seats, but in reality mechanical seat adjustments go wrong as well: cables snap, levers break off. But it makes for a better story to claim that it's only electrical systems that fail - which is just not true. The problems I have ever had with my cars have been of mechanical nature, not electrical ones.
If you've got one electronic module then you might get away with it - if you've got 50+ then you probably won't.
No, I have read the full articles - I just thought you were referring to something else from them.
I'll refrain from making a comment on that![]()
You're confusing two issues: obviously, if you have more components, and given an equal probability for any single component to go wrong, then you'll end up with more problems. The other aspect though is relevance. Not all failures of all components take a car out of commission. And of course the per-component reliability has been increasing over the last decades.
Also, don't believe that mechanical components cannot fail, in fact a purely electronical component will have a lesser MTBF than a purely mechanical one.
Right, but this is a different topic - nothing to do with reliability per se.
Here is what the problem is with CR and Which and the like: they use very crude models that aren't properly peer reviewed and that use only very crude differentiation (they weigh different types of malfunctions to express the fact that not all failures are as crippling as others) based on 2 or 3 grades and they have no way of normalising or otherwise proofing the data they get from their members. No scientist would touch such data with a barge pole. Despite that, it has *some* relevance, but that relevance is only really there where the data set is big enough. For luxury models such as the s-class, that is definitely not the case and you end up with a sample that is not even remotely statistically relevant.
Yes, s-classes do go wrong, as anything else made by humans. And because they now have components that didn't exist before, you'll see "new" types of failures.
There are other factors, like for example the fact that expectations of owners is higher for higher segment cars, etc, but I think this has already become a too long post.
I have only ever had one total breakdown of any of the s-classes that I have owned (W116, W126, V140 and V220) and that was when the timing chain on my V140 broke and put the car on the graveyard. That type of breakdown was neither related to the new car electronics nor was it a new failure for that type of Mercedes engines. Again, obviously my personal experience is not statistically relevant either, but it does illustrate a few of the points I was making above.
