a111r
- Aug 11, 2008
- Location
- North East London
- S123 240TD, S210 320cdi, S202 250TD.
It's not only for the reason of the lack of a Drain on the TC, but also it is a less of a shock to the transmission itself. And not only that it is far more beneficial because you clean the Pan and change the Filter 3 times.
This is according to some top Transmission specialists and is regarded as a higher quality way to do it. So that is what I have done in the past and what I plan to carry on doing.
But I thank you for the advice.
Why would the 722.6 or any auto be 'shocked' in having a full ATF change?
Fair enough, if you like doing it that way.
I've always used Olly's (PCS) method. It's worked fine 3 times on 3 cars and about to do the forth.
