What engine oil w221 s320 2007
MB8701
East Ayrshire
2007 Mercedes S320 W221 AMG Kit
Hi guys.
I have checked the handbook
Mb sheet 229.31
And on this forum but I cannot locate clear information on what oil is to be used for an s320 2997 model.
Can someone confirm please.
5/30 0/40?
Thanks.
Personal choice. Dependent on climate temperature, but UK doesn't have great extremes, so fairly big choice.
If you want 229.31 (Low ash - for vehicles with DPF) spec oil here is a list of all oils that have the MB Approval.
MB 229.31 - Multigrade service engine oil Low SPAsh (Specification 229.31) - Mercedes-Benz Specifications for Operating Fluids
If you want to use a later spec oil, change the spec sheet number in the drop down menu at the top.
This chart shows all suitable spec sheets for MB engines. The first three digits of your engine number are your Engine Type.
http://bevo.mercedes-benz.com/d/d/en/Spec_223_2.pdf
Thanks a lot guys - Just want a top up in the car incase I ever need it and want to make sure I keep the right one.
Thanks again
