- Apr 15, 2005
- Location
- Weybridge. U.K
- 500L ( W221 ), 2014 AMG CL 5.5 Biturbo ( W216 ) Sold, 2014 Brabus Smart ( 451 Coupe ) Mapped 130bhp
Only the best. Shell V-Power.
Just a note to say that in the USA, 'regular' gas is 89 RON and Premium is maybe 95 depending on the brand, i.e. well below the UK equivalent.:
Pains me to hear you say this (and not just because it reinforces stereotypes about tight Scots ) because, although your car doesn't have forced induction (and therefore has a lesser risk of knock with poor fuel), it's still a performance engine and deserves the best.I generally use standard 95 from my local Tesco. Even if it loses a few horses, there's plenty more where they came from
Not quite. Octane ratings in the US are based on RON+MON/2 (average of two different ways of measuring resistance to pre-ignition) which doesn't equate directly to the plain RON measure used in Europe.
'Regular pump gas' at 89 octane is roughly equivalent to our 95RON, 'Premium' at around 91/92 in the US equivalent to our 97RON.
Octane rating - Wikipedia, the free encyclopedia
I'm hoping you wouldn't put remoulds on your 63, why would you compromise the performance (not to mention throttle response, economy and general engine health) by using fuel which is only a few % cheaper?
+1 and I have used 95, 98 or 100 which we have here and I have nor noticed any differences in consumption or perfomance, except my wallet stays a bit thicker with 95I've filled up with various different grades from various suppliers both for various performance cars I've owned, and I really struggle to tell the difference in throttle response, etc. It may scientifically be better, but there is an awful lot of marketing BS thrown out by oil companies that people fall for.
..it's more that its convenient that a 8 mile round trip to a Shell garage, and the fact that my local Tesco keeps running out of their higher grade fuel!
.. there is an awful lot of marketing BS thrown out by oil companies that people fall for.
I've heard about that lawsuit, the claim seems to be more about premature wear due to the incorrect use of materials than a fuel issue. I guess the jury is still out on whether this is a real issue or just the septics having a go to get some $$$$$$!
scottishv8owner said:Just a note to say that in the USA, 'regular' gas is 89 RON and Premium is maybe 95 depending on the brand, i.e. well below the UK equivalent.
The sticker in my E63 says to use 98 RON, but a minimum of 93.
The DME operates a closed loop knock detection system.
They will knock on 95 octane if coming straight from 97+ and the DME will automatically retard the ignition timing. This wil result in atleast around 20hp less HP and midrange torque. The engine will generally feel less responsive.
If you cannot feel this it's because you've not run the car long enough on high octane to notice.
While the DME is quite quick it will take a while to overcome the negative knock adaptions per cylinder. Once the DME achieves close to the factory set ignition targets you WILL notice the difference going back to 95.
How long it takes to achieve the stock ignition targets moving to high octane will depend on the knock adaptions. In most cases the knock adaptions must be reset.
Understand opne simple fact - using high octane fuel stops detonation and is the cheapest performance upgrade you can have.
If you think 20hp is not alot then you should remove 20hp from your current setup and go drive the car. You WILL notice it.
Also, the closer the engine runs to the stock ignition targets the better the fuel economy will be.
When the DME listens to knock it not only retards ignition but also adds fuel under heavy load to full load at high rpm to protect the engine.
Yes, if there was no knock detection the factory targets would be so low that it would work just fine on 95 octane and probably never knock (until carbon build up int he cylinders takes it's course). So using high octane gives little or no performance gains on a static ignition setup.
This post was excellent and says all it needs to. Those who say you dont notice the difference, read this again and it explains why.
I have done 55K miles in my BlackSeries in 3 years and you DO notice the difference in fuel. Because mine runs out so fast (lol) I sometimes have to put normal in (dead of night, run out of superplus etc) and the engine does "pink" slighty and I do notice the difference. Put the nice stuff in and all hell breaks loose and its wonderful..
If you do 5000 miles a year, at 22mpg (do you know thats about £87 extra in fuel costs). . aint worth the scrimp when it makes such a difference
Drive it, enjoy it. . let the new fuel take effect and .. have fun
Since buying my CLK55 I've been to the pumps 106 times and 90 of those were VPower. If nothing else the car has progressively become louder and presumably all the rubbish that deposits inside the engine has been cleared out. I really don't know if the car is any quicker on VPower because I have nothing to compare it to, same goes for efficiency really.
VPower is about 7p/litre more than fuelsave and accrues double-points with driver's club. Since buying the car I have summed ~19000 points including promotions (but not including the last 3 months), this has resulted in vouchers totalling £95 so far. The vouchers are worth more when you spend them on VPower.
Results? I pay £17 per month extra for VPower and I get £4.46 back in vouchers. What's that work out as then? £13 per month? Anyone complaining about £13 per month for premium fuel doesn't deserve to drive a performance car.
