Yugguy
Ok, so I went to change the sides to led. Undid the inner drivers side cover and pulled out the bulb holder with pliers. Bulb is on at this point. I take it out and try an led. No light. Try the led the other way round, no light. I try the other leds. No light.
So I go to put the original bulb back in but it has blown. I try several other normal wegde bulbs but no light.
I check the bulb holder metal strips and bend them tight. I even connect the metal loop wires on the bulb to the wires going into the holder but no light.
