would anyone guide me to the exact location of the 40amp Airmatic fuse pls.
OceanstarBug
E55 amg
Hi all, just hopefully someone could share some light with the location of the airmatic fuse. The information I got so far is that, it's under the driver side carpet, but where exactly?? :fail a picture or detailed location could be ideal.
The problem is that it has so many things in the driver side to stop the carpet to fold down, so if I know where exactly where the fuse was, I might about the cut around that particular place. Many thanks..:o
Its probably going to be in one of 2 places--- in the fuse holder at the end of the dash [ there should be a paper guide in there] or in the front SAM [ relay and fuse holder] in the engine compartment. lots info on the net just have to look e.g. [YOUTUBE]MgQofuSzsVA[/YOUTUBE]
I see, thanks for that. Will be checking it later.. But isn't it right that there should be a Airmatic fuse under the driver side carpet? :dk:
As above
Some can have maxi fuses under the carpet but these will not be for air compressor.
It's usually in the engine bay fuse box & will also be accompanied by a relay in there for it aswell
If its a 211 then the fuse is under the drivers carpet . Lift out the carpet then look for a black plastic cover held in place by a 10mm nut , it will be in the area brhind the brake pedal . Under this cover theirs a rail will 3 or 4 large fuses , the orange 40 amp is the compressor fuse.
Thanks mate, now I found the fuse box. But there are 5 fuses all in orange and one fuse in red. Not sure which one is for the airmatic. There all do seems to have different colour plugs tho.. help...thx
