108cdi max revs only 3k how did it happen?
cartybeebnet
It is slightly more comforting to see that MB cars are suffering the similar problems to their vans.Had my 108 cdi(2000)vito serviced 2 weeks ago then told that the head has to come off to replace the glow plugs(it could run into thousands). I have not had it done, but when i picked it up the engine would not rev over 3000 revs.(safe mode apparently)but it was ok when it was taken in for the service? very hard to stomach! what can i do?
Firstly check all the connections around the engine bay.
The glow plugs are not really needed on a direct injection engine so you can leave them if you wish.
The glowplug fault will not be the cause of the limp home mode, that is a different, possibly service related, issue.
One of our 108cdi's went in for a service and had exactly the same problem when we got it back. Turned out to be a pipe disloged near the base of the windscreen. It was something to do with turbo pressure or something and took 30secs to sort.
