Hello Guys and Gals
Im very new here! Actually just joined so a "Hello to all"
I hope you guys can help me out!
I m just about to buy a 1993 Merc 190E 2.0L nice car few bit here and there on the body but generally a nice car with no rot!
So got to view the car last night after sitting up for about a year. Looked over the engine seamed good no doggy looking wiring or any missing parts. Oil looked good, although looks like rocker cover gasket is leaking ( noticeably from the front around the half moon slot, inlet manifold looked to be covered in oil ( much of a job changing the rocker cover gasket on these engines? or is there anything to be worried about by this oil on the inlet?)
So got the jump leads out and started the engine no coughs and seamed to fire straight off and settled at a even idle! OIL pressure went straight up and all seamed well!
So back out under the bonnet ! pulled the dip stick and no change in idle so happy that the compression in the correct place
Now while looking about the engine while I was doing the general snoop about and seamed to hear a whine from the inlet side of the engine seamed very mechanical and purposeful BUT i was a little set back by this!
dont think it was the water pump looked fresh and didnt seam to be coming from the front of the engine!
As i have mentioned it sounded like it was coming from the in-let manifold side.... Could it be the normal noise ? im new so i dont know
I taught might be the injector pump? if anyone has any input or advice? I know the car and can check it again if i need too!
P>S also sorry guys i know I'm asking a lot already! I think the steering shock is gone! would this make a squeak while turning the steering wheel?
If anyone has any in-put i would be most grateful!
Regards Chris
Regards Chris
