Upex
- Apr 12, 2012
- Location
- Norwich, UK
- 2001 s320 cdi w220 & 1998 slk 230 komp r170
Hi All,
The wifes slk (1998 auto 230 right hand drive) has no reverse lights (been like that since we bought it - which was funny as had an MOT the same day) and I need to get them sorted.
Firstly checked the bulbs and fuse, all OK.
I then pulled the shift unit and stripped down to the selector mech (electronic bit that has the metalic contacts for the reverse feed) and cleaned that up. Looks to be making good contact etc, but didn't help fix the issue.
Not sure where to go from here, and wonder if you kind folks can offer any ideas from your own experience please?
I think that it could be either a duff wire somewhere, faultly connection, or something more sinister.
I'm leaning towards a broken/lose wire somewhere, as the drivers door switch also doesn't function properly (doesn't activate the internal light or tell the car it's been opened etc - which I really need to sort, as you can unlock the car, open drivers door, put keys in car, close the door and it relocks itself, thinking you've not opened the door at all). I've swapped the door switches round (passenger one works fine) and this didn't help, other than confirming both switches are OK (drivers one worked on passenger side).
I've been trying to find out where the door switch wires are to check them, and wonder if the reverse wires are in the same location? If anyone can tell me the route of the door and reverse wires, that would be great, as I need to fix the door switch to.
Also, I wondered if it's possible to 'bridge' wires from the gear lever to rule our the selector contacts part? i.e. unplug it and 'jump' two wires together to see if it then lights up the reverse lights? If this is possible (to troubleshoot, not as permanent solution) how do I do it? i.e. which color wires do I need to connect to each other?
Sorry for the babble, but hopefully proivides the info needed to start working toward a fix?
Many thanks in advance,
Upex
Upex
