PobodY
^This. - Despite being obfuscated by the manufacturers, modern cars are actually quite good at letting you know what's wrong with them. In the past you'd take a guess based on where you thought the problem was (and/or what you'd seen before); now a good OBD tool points you at the right area to address the problem.
Yes, they probably are more disposable than say 50 years ago. - Just about everything is.
As time goes by, more pattern and generic parts appear; prices go down and repairs get cheaper.
There's not a whole lot going on within a car's ECU. - For this much air going in and the throttle this open, add so much fuel and adjust timing so many degrees. When coolant temperature below so many degrees, activate fast idle solenoid. When in closed loop, maintain this stoichiometry.
