television
Hardcore MB Enthusiast
Just a couple of things,dont know what car it is 215376 or 378.
Is the oil around the ECU transmission fluid, as there has been issues wher the oil has leaked into the wiring harness and ECU, with this fault a modified seal and wiring harness solves the problem. MB say that the ECU has to be replaced, this is not the case as test done by me on another forum showed where I filled up a SKY box with oil and it still worked and that is far more sensitive than your ECU.
Looking at the diagrams,yes the wheel speed sensor all come into this ECU.
I feel sure that the fault read out will solve the problem. keep us up to date on whats going on, as I follow this type of fault with great interest.
Malcolm
Malcolm
