MBManInKen
Ahhhh going up and up and up!
There's an appalling joke in there, but I think I'll pass .
It is a well known fault in the trade that on Motronic the mechanism on the idle change over switch wears. This switch is built into the throttle body and most of us just file away a piece off the stop, to allow the switch to close.
Shouldn't that just affect it at idle, which could account for the initial start issue but not driving..unless it cuts when the accellerator is released.
Maybe.
But this is slightly different, it seems to cut out when traversing bumps..although the low idle could well be throttle body.
Hope not...£££££££
It could be the throttle pot wiper losing contact with the carbon track. a strip and clean may work.
When the switch is not closing the idle can end up anywhere from too low so that it stalls or too high
Yep, I know but thanks anyway.
what I meant was it would only affect it at idle condition, when running under power it shouldn't be an issue.
Is the car only cutting under idle condition..??
It depends on how you read the first post, when cruising up to a roundabout or lights, the engine is at idle
I understood that to, but thanks for clarifying, that's why I asked..if it was at idle..
What could be happening is the engine is running under 'running' mixture instead of 'idle' mixture when idleing.
LOL..... if it is i better keep my keys safe otherwise Gina will be taking my car to the garage and swapping the bits over.....
You can discount the ignition switch for this fault, if it was that, the lamps would all come on
I might agree partially but why would the lamps come on if the ignition dies.?
Presumably they do as the engine stops.
