BAS ESP warning light on 2002 ML270 CDi
johngoth
ml270 cdi
This warning light has come on and stays on.
Reading other posts decided to change brake light switch as this often seems to be a cause of this. A new switch has been ordered.
Removed cover under dash near brake pedal to access switch to discover that there is NO switch there.Bracket is there for a switch but it is empty. Also no wiring connections.
Stop/Brake lights come on when you press the brake pedal - how can this be without a switch?
Can anyone advise me?
The warning light may be caused by a failed abs sensor or a failure of the reluctor ring that the abs sensor senses.
The most-likely one is just inboard from the back of the brake plate on one of the back wheels
