How long does it take to drain the engine?Just change the oil and renewed the filter this afternoon as the last of this good weather made it the perfect day for me. I have the Pela, same as W1ghty and been using it over the years on our cars.
Maybe 15 mins for my 9L E class ?? I normally do it on a sunny day with a cup of tea and change the oil filter as it’s pumping out so I lose track of timeHow long does it take to drain the engine?
I would say, if you have not got a Pela, consider buying the unit for Lidi. Saves moving the dirty form the Pela to container and looks a good bit of kit....if it works for a few years!
Mine has
About 10 mins depending on how big your engine is. Never had an engine not start after using thisHow long does the electric pump take to fully drain also does it not drain your battery?
Unless you forget to fill it back up with oilNever had an engine not start after using this
Unless you forget to fill it back up with oil![]()
If the Lidl oil extractor drains your battery then it’s time for a new battery...!Do you mean the electric one? If so have you used it and how long did it take? I was a bit worried it may drain the battery before it had finished
And even then, it would still start... ( unless there was a built in low oil sensor that would prevent it from starting ) but the question is how long it would run for...Unless you forget to fill it back up with oil![]()
Ive always drained but thinking of using a pump, looking at this you have shown, i'm a great panicker looking at the picture how about that black plastic coming off in the engine !!If anyone is interested, the Lidl one is back on sale next Thursday for £9.99. They have some other goodies too including a CTEK
Ultimate Speed Oil Pump - at Lidl UK
Ultimate Speed Oil Pump - For pumping out engine oil, diesel and heating oil – ensures clean and easy oil changes Powered by a 12V car battery Easywww.lidl.co.uk
Deluxe Wines from Thursday, 02.02. at Lidl UK
Deluxe Wines from Thursday, 02.02. at Lidl UKwww.lidl.co.uk
Burn him !!I still prefer the old fashioned sump plug drain method![]()
