Seems a pity to chop up ends made for a TT install.
It's just an exhaust system, not the holy grail...
In 2007,Hughes considered the exhaust system along with the twin turbo so valuable that they sold their remaining stock for 1000 sterling.
The down pipes are swaged to the cat and may or maybe not welded.
Either way they can easily be removed at that point, no different then changing out a converter and saved for the rare TT turbo build that doesn't have the exhaust.
The M103-12V kit I bought from had a separate pair of downpipes.
Billy should first see if the down pipes mate up with his stock manifolds.
If not an exhaust specialist has the bending and swaging tools to replicate the down pipe with any modification that Billy requires.
Anyone installing a TT kit today will probably modify this section and use twin metal spun metal cats for higher flow/lower back pressure.
Also a second "tuning" bung has to be installed as the stock O2 sensor that controls the K-Jet and HFM uses a narrow band sensor, so a wide band sensor must be installed to program AFR's.
Not rocket science, just some SS tubing that needs to be cut, bent, swaged and flanged....happens many times a day across the U.K...
Cheers
Ed A.
