Billy's W124 Coupe Project
Parts list
For those interested in part numbers here's the lot, may come useful for 124 owners. Obviously some parts are generic and some are specifically for 1240522 chassis.
Part Part No. Qty
ANTI ROLL BAR FRONT
Front ARB Bushes- A1243234585 2
Front ARB Wishbone Bushes- A1243235185 2
Front ARB Clamp Left- A1243230426 1
Front ARB Clamp Right- A1243230526 1
Front ARB Bracket- A1243231140 2
Front ARB Wishbone Bracket- A2013232340 2
Nuts ARB for Brackets Wishbone- N913023008003 8
Bolts for ARB Clamps- N304017008021 4
Screw for ARB Clamps- N914125010319 2
Washer for ARB Clamps- N000000003386 2
Plate for ARB Clamps- A1243230025 2
Sportline ARB- A1243236865 1
UNDER TRAY
Undertray- A1245240930 1
Under tray side mounts- A2015240347 2
Undertray side mount Bolts- N304017008021 2
Undertray side mount Nuts- N910113008003 2
Undertray bolts- A2019900536 4
Undertray clip unit- A0019949845 4
FRONT and REAR SUSPENSION
Shock Mounts- A1243201444 2
mount washers- N000125008445 6
Mount nuts- N913023008003 6
Shock Mount repair kit- A1249900099 2
Rebound stop- A1243230032 2
Rear shock mounting kit- A1249900399 2
FRONT AXLE
Front Wheel Hub- A1243302225 2
Front nut hub to Steering knukle- A2013340072 2
Front Washer hub to steering knuckle- A2013340076 2
Screw Lower control arm to Knuckle- A1299901001 2
Nut Lower control arm to knuckle- N000000005295 2
Centering PIN- A1293320074 2
Clamping PIN- N001481012018 4
Bolt to steering arm to knuckle short- A1244210571 2
Bolt to steering arm to knuckle long- A1299901401 2
Front Steering Knucle Left- A1243300420 1
Front Steering Knucle Right- A1243300520 1
Wheel Bearing repair kit- A2013300251 2
Steering lock stops- A2013300080 2
Steering Arm Left- A1243321220 1
Steering Arm Right- A1243321320 1
Eccentric bolts kit- A2013300018 4
Front Brake Plate Left- A1244202544 1
Front Brake Plate Right- A1244202644 1
Front brake Sensor screw- N914125008533 4
Screw cover plate to knuckle- N914125006501 6
STEERING HOSES
Steering box hose- A1244663181 1
Steering box hose- A1249978582 1
Steering pump hose- A1244663581 1
Power steering line- A6032300056 1
Protective Hose- A1269972982 2
STEERING LINKS
Steering box cover srcew- N910105006002 2
Tie rod and drag link nut- N913002010010 4
Drag link to pitman arm nut- N910113012002 2
Screw shock absorber - A1249900004 1
Shock absorber nut to frame- N910113010002 1
Shock absorber screw- N308676010023 1
Steering box cover- A2024660138 1
protcective plate cap- A1244630890 1
protective cap screw- N914128004303 1
Intermediate lever kit- A1244600119 1
Steering shock absorber- A1244630432 1
Drag Link- A1244601205 1
Tie rod LEFT- A1243300903 1
Tie rod RIGHT- A1243300803 1
intermediate arm- A1244631310 1
GEARBOX
Gearbox filter- A1262770295 1
Gearbox gasket- A1262711080 1
Gearbox sump- A1262701012 1
Gearbox oil line Left- A1041800420 1
Gearbox oil line right- A1041800620 1
Speedo cable- A1245400568 1
Starter motor- A005151660187 1
EXAHAUST
Heatsheild firewall- A1246800022 1
Heatsheild Control arm- A1246821771 1
Main floor heat sheiled- A1246822871 1
Main floor heat sheiled above cat- A1246821971 1
Rear heat sheiled- A1246820371 1
Screws- A2039900036 12
FUEL PUMP
Fuel pump tray- A1244781237 1
Fuel pump tray nuts- A0039900251 4
Fuel pump insulation- A0000910282 2
Fuel filter insulation- A0000910182 1
Return fuel line- A1234703564 1
Feed fuel line- A124320967226 1
Fuel Hose- A1244708075 1
Fuel breather pipe- A1244714415 1
Fuel clamp- A2014760840 6
Fuel clamp damping strip- A2014760184 6
Fuel clamp daming screw- A2019920030 6
fuel pump- A0030915301 2
Fuel hose from tank to filter- A1244706975 1
grommet- A1009970881 1
Fuel hose from filter to feed line- A2304768726 1
Hose from return- A1244713223 1
Fuel pump bracket A2014785140 1
Rubber Mounts- A1244780582 4
REAR BRAKES
Rear Brake line centre- A1234207928 1
Rear Brake line left- A1234205728 1
Rear Brrake line Right- A1234206428 1
Brake distributor- A0004284224 1
Foot brake line- A1244201185 2
Footbrake Shackle- A1244200289 1
Retaining spring to barake hose- A0004280673 4
foot brake grommet- A1159970681 2
foot brake screw- N914125008511 2
REAR SUBFRAME
Subframe Front mount bolt- A2029900404 2
Subframe Front mount stop- A1293520146 2
Subframe Rear mounts kit- A1243506708 1
Differential mounts- A1243527765 2
Differential mount bolts- A2023500270 2
Differential screw- N000912010224 1
Differential spacer washer- A1243572052 1
Differential front mount- A1243511342 1
Differential nut- N910113010000 1
Diff sender unit grommet- A0009973181 2
Diff sender screw- N914125006502 1
Diff sender bracket- A1405451140 1
Diff sender bracket screw- N000912006095 2
Diff Sender bracket clamp- A1295460243 1
ANTI ROLL BAR REAR
Rear Sportline ARB- A1243261965 1
Rear ARB Rod- A1243200289 2
Rear ARB Clamp- A1233260926 2
Torsion Bar nut- A2109900251 2
Rod screw- N304017008043 2
Rod Nut- N910113008003 2
Rear ARB Screw mount- N910106008006 4
ARB bushes- A1243260181 2
Rear Propshaft coupling- A1704100015 1
REAR AXLE
Rear wheel Bearing kit- A2029800016 2
Seal ring- A1249971240 2
Arm Covering- A2033520088 2
PIN- A2019970010 2
Screw for covering- A2109900336 4
**ADDITIONAL PARTS**
Wheel Bearing LEFT A2023509408 1
Wheel Bearing RIGHT A2023509508 1
Control Arm A2023500206 2
Mounting kit control arm A1243506706 2
Flange A1243500746 2
Tie Rod and Parts kit A2103502153 2
Strut A2103503306 2
Bolts kit A2103504506 6
Sleeves A2103520043 6
Thrust Arm A2103503806 2
Thrst arm cover A2012520988 2
Protective plate left A2104201444 1
Protective plate Right A2104201544 1
Protective plate screw N914125006501 12
Gasket A2014230080 2
Brake shoes and kit A1244200720 1
Brake shoe cylinder pin A1084270074 2
Brake shoe Shackle A2014200589 2
Brake shoe supporting bush A1244230050 2
Brake shoe adjustment screw A2014200373 2
Brake disk screw A2014210171 2
bushing range selector A1159920310 1
rear engine support A1242420501 1
Engine support screw N000933010164 4
Engine support washer N007349010007 4
Engine mounting screw A1249900401 2
undermount A1246100232 1
undermount nut N080705018002 2
Front Control arm LEFT Sportline A 124 330 36 07 1
Front Control arm RIGHT Sportline A 124 330 37 07 1
Bracket (cat) A 124 610 23 25 1
Rubber ring A1244780082 4
Nut for bracket A0039900251 4
Bracket A1244780240 2
Screw for bracket N007985005157 2
Refurbed diff has finally showed up!
And now to sort this mess out!
You're clearly trying to buy a brand new c124 from the parts desk as a self assembly kit! can't fault you.
All good Terry, all parts have been assorted in their separate boxes and labeled. You won't go wrong!
..all credit to the Mrs organisation skills military style, got this lot separated super quick. :thumb:
Feck'n hell, Billy!
:thumb:
A drug addiction can be less expensive......:crazy:
Great job young man :thumb:
Hope you are planning on keeping this car now billy!
Its an amazing W124... I thought my AMG TE was clean until I saw yours!
Must detail my engine bay now...
BILLY
Have you thought about buying your own dealership as you could
probably save money by getting everything at trade prices? !!
Cheers Jay, I made a decision very early on that this motor was for keeps and with that in mind just following through with plans. I got a lot of inspiration on here in the early days, reading your very own projects, Ed's 300 TT, KLP's SEC and so on, remarkable stuff. :thumb:
That is one hell of a parts stash - now to just remember where they all go! :dk:
Spruced up the recently acquired propshafts over the weekend. Needed a rear shaft only as the front is already talking 320, but seeing as i got a good deal for the pair from Mercman in decent overall condition thought why not.
...hanging off a ladder!
finished in Satin Black with some new bits to go with it.
Billy's car is looking awesome as the work progresses.. WGMB are doing an amazing job on it!
Swapping W124 Seat Bases - Standard Electric to Memory
Well, today I had a go at swapping seat bases for my future install of memory front seats.
I've taken some pictures along the way. These seats are wonderfully put together and as always, you figure it out once you start taking things to pieces! It's been a total PIA that's for sure! What feked me off the most was taking the back rest off. :mad: But all in all i'm satisfied now that i've fully understood the differences between a normal electric seat and one with memory functionality. The motors are different with Potentiometer's attached to them, and of course the inclusion of the memory module box.
Here's some pics of today's effort:
Memory Seat base:
Standard electric seat base
Potentiometer's (black) attached to the motors
Without
Side by side
Left is the Memory seat, Right is the normal electric seat, again notice the difference in motors.
Left is the back rest motor and right is the head rest motor.
Looks good Billy, in the first pic is the memory module in the right place, I always thought they should be at the front of the frame to allow the car loom to plug in...??
And that green looking fibre cushion in the backrest, is that a new one...?
