KLP 92
As many of you will know i've been having sets of wheels refurbed for some time by this company. I've recommended these chaps to alot of people of the years but i have found the recent level of quality appauling. I had 2 sets done 6-8 months ago.
http://www.wheelrefurbishing.com/
The 16 inch wheels were diamond cut. I am aware about the lacquer lifting but found the original wheels lasted 7 years before they were this bad!! When i rang in and spoke to Andrew i was fobbed off and told when the wheels were installed the fitter must have been careless and broken the lacquer. Well i fitted these myself and i'm extremely careful!! Well 2000 miles later and they are looking like $hit.
Now i can believe one set going wrong but i had the 18 inch SL 2 piece split rims redone by the same chap at the same time. The centres were done in a bright silver and the lips diamond cut. The paint in the cetres is peeling up from underneath, the lacquer is perfect but just look at the pics. The lacquer on the lips has gone hazy and is already lifting. The car has only done 1000 miles! All 4 wheels equally as bad.
I hasten to add that these wheels are washed every few days at the latest, no chemicals used. I refuse that the quality of the refurb is acceptable. I have basically been told that if i get them redone i will get a slight reduction in cost!!! I am extremely dissatisfied by the level of service i have received and recommend that you guys use another company.
