I've just finished replacing the seals in the high pressure fuel pump on my 2003 W210 E320 CDi after a leak on one of the heads, I've also replaced all the plastic fuel pipes.
I have spun the car over about a dozen times now and nothing yet!
I've had to put the battery on charge now as its too low to carry on.
There does still seem to be air bubbles in the lines so do I just keep cranking?
The initial problem came out of the blue and I wondered if the pump leak was the only problem for the non starting? Immobiliser fault or key fault ect.
However I have just given the car a slight sniff of easy start and it fired for a second.
There are now no signs of leaks, the fuel is up to the rail, is this just a case of keep trying?
