Just fitted pump back on, pre filled the pump with diesel and a syringe through the one way valve.
Pulled the feed pipe off the top of the fuel filter and filled the filter to the top, also held the feed pipe vertical and back filled with the syringe!
Went to start it and first start cycle nothing
Second start cycle....nothing and I could see air in the lift pump outlet pipe, took the pipe off then back on again, swiveled the pipe to make a good seal.
3rd start cycle.......Started instantly!!!!!! :bannana: :bannana: :bannana:
No fuel leaks and a running car.
Many thanks to everyone who helped I am very greatfull
It was the valve in the end!
Just a word of warning....if you buy a pre used pump or clean your own and leave it for a while before fitted, check the valve and pre lube it with diesel!
