MBrummm
- Aug 10, 2015
- C350e Premium 'Brilliant' Blue
Sorry, not had chance to book it in yet. V.busy with work n stuff boohoo
In response to having temp gauge update... Still not had mine done boohoo
I had mine done only to find out it only shows temp on the screen with total distance covered on, which I don't really use.![]()
The maximum charge rate can be set in the menu options on the instrument panel. I seem to remember that the options are 8A, 13A and maximum (16A).
There are also two selectable charging rates on the brick at 8A or the full 13A.
TBKing said:Just an update on mine: Ordered mine at the start of January and was given a provisional delivery date of mid-July (7 months), which fitted with the lead times most had been quoted. I've had an email from fleet today and I've been given a revised delivery date of the 2nd of May...!!!! Impressive, considering a guy in my office ordered his CLA in November and isn't due to take delivery until mid-May. Just over 2 months to go :bannana:
in hyacinth red and currently have an estimate of mid-July. Seems the vast majority of folks on here have ordered in Brilliant Blue - not seeing many in Red.
One thing I would say from personal experience is to be careful charging at the full 13A. My outdoor socket has failed with a big crack running across the face plate. I presume this is down to heat generated from a continuous 13A draw.
It would be good if anyone is aware of an outdoor socket that's officially rated for 13A continuous. I would suggest that's one major benefit of having the charger installation done.
hyp3rtoo said:That gives me hope. Ordered at the end of January, fully loaded estate with premium+ (without the air balance kit - £300 odd quid for an air freshener... really?!) in hyacinth red and currently have an estimate of mid-July. Moving from a 13 plate E220 CDI - looking forward to the drop in BIK and a bit more poke in the tank. Seems the vast majority of folks on here have ordered in Brilliant Blue - not seeing many in Red.
Hi, those were the same sort of timelines I was given but ordered end Dec and delivery mid June. Who was yours through?
Please be aware of a design fault with the plug-in charging cover as mine has fractured on the hinge section and unfortunately it is moulded to the rear bumper assembly. The hinge cover costs approx. £12.50 and to replace the hinge section will cost £1,700 for a replacement bumper and my car is also required for two weeks to carry out the work! For those of you with the car take a look at the hinged flap strength as it certainly worth knowing about my issue. I'm not sure whether the flap hinge was already fractured on deliver as the cover came off in my hands when I tried to open it.
