TheCorm
You know what? I think you're right. It did feel more lumpy in Eco.
Why??
At a guess, the airmatic suspension must use some power so perhaps they put it into a low power mode where it doesn't adapt and cushion as much?
Why??
Anyone have any ideas what the depreciation values are likely to be on these for 2 years and 3 years?
60 mpg on long motorway journeys ! I can't better 45 mpg on long motorway journeys
My daily journey of 21 miles I do get >99.9
I generally have individual setting with suspension and steering as sport, air as comfort and engine as eco. Now at 18k miles I generally get 40mpg and even got 47mpg on a decent run all without charging. Makes a big difference in eco mode as the engine breaks a lot more for you to regenerate. Doesn't feel so sporty but kinda getting used to waft around everywhere instead of screaming around. Makes you appreciate it more when you do engage hyperdrive, I mean sport+. Having said that I find I use sport more than sport+, as the latter holds each gear longer so does sound like you are revving the pants off it even when you are slowing down after an overtake. Don't know why but I find myself quickly manually going up a gear to calm it down. Sport is just like a normal quick car changing up when you back off the accelerator.
Do a fair bit is all electric driving and charge every day and just changed mine @ 9500 miles edges of tyre perfect centre was down to 1.6. comment was sir has a heavy right footSorry, also forgot to mention after 18k miles I still have 4mm tread on the back and 6mm on the front. The guy at Mercedes was quite shocked as folk apparently have only been getting 8k to 12k on the first set. Perhaps all that charging and using electric so instant torque is shredding rubber. Be interesting to hear what other folk are getting out of their tyres? I'm not exactly driving miss daisy either at times, pretty mixed driving.
4949 miles
3580 engine off
Avg speed 30 mph
Avg economy 95.1 mpg
If I continue like this the engine itself will have done about 10k st the end of my 3 year lease!
