MaidenheadMerc
- Jul 12, 2015
- C350e
Hi MM,
Just how does the charge lead locks into the car, and is it a physically secure connection ? Also what duration did you leave it and charge percentage before and after......
B&O (due mid Nov)![]()
When you plug the connector into the car and it begins to charge you hear it lock in place, obviously with a 3 pin connector someone could switch it off or unplug the other end, but fingers crossed they don't!
I plugged in at around 18% (as the battery doesn't really drop below that in normal driving without the engine charging it a bit) and came back a few hours later with it fully charged. You can check on the progress though with the Mercedes Me app.
I'm using a 3 pin connection at work and it takes around 3 hours to go from 20% to 100%.
