Funny - I noticed the same thing for the first time yesterday. I've had the car 14 months. I'll check for leaves !
I also have this sound, I first noticed it about two weeks ago. Its like a clicking / stretching sound on the passenger side that starts about 15-20seconds after starting, and lasts about 20 secs.
The fact that we are all getting suggests that it isn't something individual, but I certainly think it is air con / heating related as it has only started since the weather has got colder. That said I don't remember the noise last winter.
Quick question...
I'm currently unable to charge at home, will leaving it in hybrid mode all the time keep sufficient charge in the battery to use all 275bhp? Or is it necessary to use the charge mode from the engine from time to time?
Quick question...
After enjoying a lovely warm pre-heated car this morning the AC noise soon became irrelevant after a kind gentlemen rear ended me at high speed causing extensive damage to the back of my 350Watching the police pull off the panels so they could move it to safety almost brought a tear to my eye after all the hours lovingly cleaning her.
thankfully I'm ok but MB are estimating that I won't get her back until mid - end of Jan.
That said it hasn't had its detailed inspection yet, whilst there is the expected panel work, boot and exhaust damage, the rear passenger wheel is bent and twisted, and it might be the batteries took a smack as well though there was no failure warning after the accident. If they are damaged, along with a bent chassis, it might be bye bye 350e, I hope not, but either way, it's a long wait through the coldest months when the pre-heat is the best feature.
Sorry to hear that, hope you are OK.After enjoying a lovely warm pre-heated car this morning the AC noise soon became irrelevant after a kind gentlemen rear ended me at high speed causing extensive damage to the back of my 350Watching the police pull off the panels so they could move it to safety almost brought a tear to my eye after all the hours lovingly cleaning her.
Did you have PRE-SAFE, and if so, did you notice it trigger? (It's supposed to brake if you're stationary and tighten the seat belts).
It worked for me recently, I was fiddling with the sat nav and didn't notice a car in front stop to turn off. I got the warning beep, brakes engaged and seat belt tightened. Result: accident avoided.
That would only have helped if the other guy had PRE-SAFE.....
In the future their will probably be a system that detects someone is about to rear-end you and moves you forward though....
I previously measured mine and it consumed 6.5kWh from 10% to 100% and no pre-heat which suggests some losses (as to be expected) during the charging process.I'm pretty sure the esteemed @CaptainChaos means that you will rarely have less than 10% charge because the battery management system gets very thirsty at 10% and charges automatically to keep charge at 10% or higher. Mine's never been lower than 9%.
If you floor it on an oval I guess you will eventually drop to something around 211bhp (or maybe less if the computer decides your need for speed is less than your battery's need for juice).
On a geeky note, I would love to know more about the battery. On the face of it, the battery appears to be 6.2kWh and the 10% level is 0.62kWh. Which means that when I squeeze 10 miles of pure e-mode out of a battery I'm using 500wh per mile. That's shocking compared to pretty much any BEV. Even a Tesla driven hard wouldn't use much more and I pretty much have to coast downhill to get 10 miles. It makes me wonder if some of the battery capacity is being held back for technical reasons.
